Discussion topic: WiFi no working
Message posted on 15 Dec 2025 11:06 AM
WiFi no working
Hi
Our WiFi has suddenly stopped working. On the test it shows no issues but it isn't connecting to WiFi
can you help please
thank you
Message posted on 15 Dec 2025 11:11 AM
Re: WiFi no working
@LyndseyE
The first thing to try (even if you’ve already tried it) is to use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
