Discussion topic: WiFi - no internet connection
This message was authored by: AndyBeeve
Your tests say my wifi is ok but I have no internet connection
Re: WiFi - no internet connection
@AndyBeeve
You haven’t contacted Sky by posting here. This is a customer ▶️ customer discussion forum where we try to help other customers.
The first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
