Discussion topic: WiFi mesh best setup
This message was authored by: andywhitehurst
Hi all,
My broadband setup is sky gigafast, sky router (black upright one) sky q box and one minibox.
The Q box and router are literally next to each other, with the mini box in a bedroom. Is there any benefit to having the 2.4 and 5 ghz channels switched on on the q box being so close to the router??
Re: WiFi mesh best setup
@andywhitehurst  If the Q box is connected by ethernet then you can turn the Q box's WiFi off if you want but it wont make any real difference as the 2 dont interfere with each other.
Avatar for andywhitehurst
Level 2 icon
Turning the WiFi channels off on the Q box has resulted in a much more stable WiFi connection.
