Discussion topic: WiFi max
This message was authored by: Hensetl
WiFi max
I have just joined the WiFi max. But I can't find anywhere on the app for the parental controls. Can someone help or advise what to do please.
Re: WiFi max
@Hensetl
There seems to be a delay in the administration tabs appearing in My Sky for some Max subscribers: Sky is investigating this.
Avatar for Hensetl
Re: WiFi max
Thanks you! Is there another way to access parental controls if they aren't showing on the app!
Re: WiFi max
@Hensetl
No: the Max Hub doesn't have much in the way of local adminstration through a web browser.
