2
This discussion topic has been answered Discussion topic: WiFi max pods
This message was authored by: harveyluke
WiFi max pods
When I upgraded to WIFI max, I was under the impression the hub came with up to 3 max pods. I wanted to upgrade as I wanted to use the max pods to bring Ethernet into my office room and bedroom to get Ethernet internet level speeds. No max pods were included in the box that’s arrived with the hub
Re: WiFi max pods
@harveyluke
They are not supplied unless you contact Sky and ask for them:
150 from a landline phone is the number to call Sky on otherwise:
Select "No, I still need help" at the bottom on the above link.
Re: WiFi max pods
@harveyluke
This message was authored by: splatto
Re: WiFi max pods
You can only get one from a phone call. More than one and you need an engineer visit to test for dead spots and optimise pod location.
