Discussion topic: WiFi keeps pausing and restarting
Message posted on 06 Dec 2025 03:32 PM
Good afternoon I have tested WiFi and hub etc and everything has been passed as no problems but my WiFi keeps pausing and restarting
Message posted on 06 Dec 2025 03:42 PM
Re: WiFi keeps pausing and restarting
Your duplicate thread has been removed as you already have this one.
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
