Discussion topic: WiFi keeps going off and on
Message posted on 12 Dec 2025 12:14 AM
So my wifi has been going off and on all day every 5 minutes is anyone else having this problem or recommend any fix's that's not a service check as that just lies as always so the middle light keeps going amber
Message posted on 12 Dec 2025 12:35 AM
Re: WiFi keeps going off and on
Message posted on 12 Dec 2025 01:20 AM
Yeah I think at this point even if I didn't have internet it would tell me I did I never bother with it as it's always everything seems fine when clearly not that's why I don't understand why people in the reply's always suggest it
Message posted on 12 Dec 2025 05:21 AM
@KeneRy
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
Message posted on 12 Dec 2025 05:22 AM
@Fayfin
Your issue is different. Any broadband issues between midnight and 7am could be essential overnight maintenance taking place which is carried out then to minimise disruption. There’s no pre-warning of this. See this pinned post at the top of the Broadband board from Sky which could be relevant any night this happens…
https://helpforum.sky.com/t5/Broadband/Important-Notice-Scheduled-Broadband-Maintenance/td-p/5151847...
If you have an ONT box displaying a red light, see this further advice…
Hopefully it’s back up and running before 7am. If it’s not, try restarting your hub or try the advice given to @KeneRy
