Discussion topic: WiFi keeps dropping
This message was authored by: TT1981
WiFi keeps dropping
WiFi keeps randomly dropping, even when the weather is fine and no rain. Then after a minute it reconnects itself, but it does this quite a few times throughout the day.
Re: WiFi keeps dropping
@TT1981
When this happens what lights are lit (or not) on your hub ?
Avatar for TT1981
The two end lights are solid green but the middle light flashes orange.
@TT1981
The first thing to check is this link to see if there are any outages in your area, it can be a bit slow at picking up issues so if nothing shows perhaps try it again later:
If nothing shows then try this line test:
This message was authored by: Me134
As an aside, heavy rain can affect a satellite signal to your Q or HD+ box but doesn't affect the broadband connection or especially, the internal WiFi signal.
Not a Sky employee
Sky FTTP 500Mb to Max Hub (WiFi disabled)
Pair of TP-Link Deco BE65's in AP mode used for WiFi access with MLO enabled, main Deco hardwired to Max hub
Avatar for TT1981
Thanks all. The fault has now been fixed.
