Discussion topic: WiFi keeps dropping
This message was authored by: Jason154
WiFi keeps dropping
Hi our WiFi keeps dropping and our phones switch over to data and it's happening all the time. I've reset the router, moved it and changed the WiFi settings but nothing has changed. Yesterday when trying to watch tv on the sky q box it said we had no internet connection, when I went to settings and network you could see it connect then disconnect then connect again and disconnect a number of times.
Re: WiFi keeps dropping
@Jason154
Try running the line test here to see if any faults are found:
If this is of no help give Sky a call to report it to them.
