Discussion topic: WiFi keeps dropping out
This message was authored by: Laurasearch
The WiFi is constantly dropping out
Re: WiFi keeps dropping out
@Laurasearch
The first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
This should identify if there's a known fault, perhaps affecting multiple households.
▪️I AM NOT A SKY EMPLOYEE ▪️
