Discussion topic: WiFi keeps dropping out
Message posted on 05 Sep 2025 11:59 AM
My WiFi over the past few days keeps dropping out maybe 5 times a days for approx 5-10 minutes
Message posted on 05 Sep 2025 12:31 PM
Re: WiFi keeps dropping out
@Clareth1
Wi-Fi and broadband are different. Wi-Fi is the wireless connection between your devices and your hub. Broadband is the actual internet connection provided by your ISP (Sky).
If your broadband isn’t working use this link to check to see if there are any problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update).
