Discussion topic: WiFi keeps dropping out
This message was authored by: ad1974
For the last 3 days our WiFi keeps dropping out it's completely off now
Re: WiFi keeps dropping out
@ad1974
If you haven’t done it already use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
