Discussion topic: WiFi keeps dropping out
This message was authored by: Lindsey1967
The router is showing fine as is the app checker but wifi keeps
dropping out and we lose connection
Re: WiFi keeps dropping out
@Lindsey1967
In addition~
▪️This link providers information about the coloured lights on the various hubs
▪️ For any customers working from home remember that Sky Broadband is a domestic service so you don’t receive any extra or quicker support.
▪️I AM NOT A SKY EMPLOYEE ▪️
