Discussion topic: WiFi keeps dropping out
Message posted on 25 Feb 2025 09:55 AM
I have a sky hub and the WiFi keeps dropping out. It has happened a lot over the last few days and today it is not connecting at all. I've rebooted the router multiple times with no success. When I check connection all comes back fine - but still no wifi. To me the router could be faulty?
wifi light flickers amber, then solid, then off. It momentarily goes green, but 30 seconds later it drops and flashing amber comes back. This has been happening for the past 4 hours.
Message posted on 25 Feb 2025 10:36 AM
Re: WiFi keeps dropping out
Try going through this:
Message posted on 25 Feb 2025 10:46 AM
Hi, I've been through this a number of times - it just loops me round and round. Run tests for WiFi, WiFi fine, then back to 'what lights mean. So no luck unfortunately
Message posted on 12 May 2025 09:19 PM
DId you ever get a solution? Ours is doing the same!
Message posted on 12 May 2025 10:17 PM
Try running the line test here to see if any faults are found:
If this is of no help give Sky a call to report it to them.
