Discussion topic: WiFi keeps dropping about every half hour
This message was authored by: HelenFlemington
Please can you help - our wifi keeps disconnecting roughly every half hour.  Do we need a new router? Xx
Re: WiFi keeps dropping about every half hour
@HelenFlemington
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
