Discussion topic: WiFi keeps disconnecting
This message was authored by: Nnamdo
Greetings, My Internet seem keeps disconnecting at home for the past three days. Sky apps keeps saying no issues, but I can no longer work from home. Has anyone experienced such?
Re: WiFi keeps disconnecting
@Nnamdo
Start by using this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
If you’re still having problems you may need to report it to Sky. The easiest way is to dial 150 free from your Sky Talk landline (if it’s still working).
Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky allow customers working from home to use it, they won’t receive additional or quicker support.
This message was authored by: LizaH2
I'm having issues today. At present, we have no WIFi connection. I am based in Tadworth, Surrey. And you?
