3
This discussion topic has been answered Discussion topic: WiFi keeps disconnecting every day
This message was authored by: BeeMatt08
Every night I switch the TV on and the WIFI has disconnected overnight! I have to try to reset. Switch off router and put the password in.
I do NOT want to do this every day.
why is it doing it?
only recently had it installed.
not impressed to be honest
Avatar for BeeMatt08
This message was authored by: BeeMatt08 Answer
Re: WiFi keeps disconnecting every day
Hi. Yes they are. It's not a big lounge! Just wish I'd stayed with Virgin 😔😔
@BeeMatt08
Are the router and TV near to each other, could it be this TV has a weak wifi signal to it ?
This message was authored by: Cox-Boltons
So I had this problem well living some where else was give new WiFi hub and sky box did not not make any difference someone came out and it stopped. Fab you think I've moved up country in land and had the engineer out to fit new WiFi etc and it's started again I've let it go for a bit but it's still going on I'm disabled and somtimes I not able to move around to press buttons etc it's very frustrating
