1
This discussion topic has been answered Discussion topic: WiFi keeps cutting out
This message was authored by: CatrionaC
My WiFi keeps cutting out but when I do the online checker it says it's fine when it's not this has been 2 days now
Re: WiFi keeps cutting out
@CatrionaC
If you haven’t done it yet you can use this link to check to see if there are any broadband issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again later).
@CatrionaC
