Discussion topic: WiFi keeps crashing
Message posted on 07 Oct 2025 08:41 PM
WiFi keeps crashing
Message posted on 07 Oct 2025 08:43 PM
Re: WiFi keeps crashing
Same here, haven't been able to find any reason for it as yet
Message posted on 07 Oct 2025 08:44 PM
Use this link to check to see if there are any broadband issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour later).
Message posted on 07 Oct 2025 10:32 PM
This explains the lights on the hubs:
