Discussion topic: WiFi keeps breaking down
This message was authored by: Dotty8
My internet keeps going off
Re: WiFi keeps breaking down
@Dotty8
Wi-Fi and broadband are different. Wi-Fi is the wireless connection between your hub and your devices. Broadband is the internet connection provided by your Internet Service Provider (Sky).
If you have a broadband issue the first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
