This discussion topic has been answered Discussion topic: WiFi keep dropping out
Message posted on 01 May 2026 06:28 PM
Hi
can you help my WiFi keeps disconnecting from my phone when I go upstairs
Message posted on 01 May 2026 06:40 PM
@Jamesarchibald Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
