Discussion topic: WiFi keep dropping in and pit
This message was authored by: Rache3
My WiFi keeps dropping in and out all day! Very frustrating
Re: WiFi keep dropping in and pit
@Rache3
Use this link to check to see if there are any broadband issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour later).
