Discussion topic: WiFi issues
This message was authored by: Jessicawallwork
WiFi issues
When will my WiFi be back on? Also I have requested an engineer to come and fit my new WiFi box but I have got no reply to that either. It has been sat there for 2 months in the box. I will be swapping to go elsewhere if this does not get resolved
Re: WiFi issues
@Jessicawallwork  Is there a reason why you can't connect your hub to the incoming connection either a mastersocket or ONT.
Be aware you're not contacting Sky Customer services by posting here, we have no knowledge of the issues you're experiencing without you providing some details.
Also threats to go elsewhere won't make anything happen and it's likely another provider will have similar issues.
Re: WiFi issues
Why is it off ?
What new wifi box, do you mean a broadband hub/router, is there any reason you can plug it in yourself ?
