2
This discussion topic has been answered Discussion topic: WiFi issues
This message was authored by: Alice06
WiFi issues
Hi my WiFi isn't working
Re: WiFi issues
@Alice06
The first thing to check is this link to see if there are any outages in your area, it can be a bit slow at picking up issues so if nothing shows perhaps try it again later:
If nothing shows then try this line test:
Re: WiFi issues
@Alice06
Re: WiFi issues
@Alice06
The extremely hot weather won’t be helping but use this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky accept it's fine for customers working from home to use it, they won’t receive additional or quicker support.
▪️I AM NOT A SKY EMPLOYEE ▪️
