Discussion topic: WiFi issues
This message was authored by: Wilson30
WiFi issues
My WiFi keeps dropping, and going off, even when it says I have it. It's affecting the tv freezing some of the time.
Avatar for Wilson30
Level 0 icon
Re: WiFi issues
WiFi keeps dropping
This message was authored by: Sid21
Re: WiFi issues
I've been having same issues with mine for over a week now, even with additional puk
  • This is as bad as virgin
Re: WiFi issues
@Sid21 @Wilson30
This could be caused by a poor signal in certain rooms as this is something that comes up on here on a regular basis so try going through this to see if it helps:
https://www.sky.com/help/broadband/my-broadband-speed/improving-wi-fi-signal-to-my-devices/articles/...
If not and if you have Wi-Fi Max on your account then Sky will loan up to 3 pods as you can read about here:
So you can either call them on 150 from a landline phone or a mobile that has a Sky sim in it or Select "No, I still need help" at the bottom on the above link.
