3
This discussion topic has been answered Discussion topic: WiFi issues
This message was authored by: Soriya
WiFi issues
I have issues with the WiFi and this is a reoccurring issue for some weeks now.
Re: WiFi issues
@Soriya
Wi-Fi and broadband are different. Wi-Fi is the wireless connection between your hub and your devices. Broadband is the internet connection provided by your Internet Service Provider (Sky).
Re: WiFi issues
@Soriya
Avatar for Soriya
WiFi issues
WiFi broadband keeps cutting out and I work from home this has gone on all week. It's completely cuts out late evening and through the night. This is not good enough.
Re: WiFi issues
@Soriya Did you follow the guidance when you last raised this issue?
I've merged this latest post to the last one you raised as the same issue, please follow the steps posted by @Daniel0210
