Discussion topic: WiFi issues
This message was authored by: Tara66
WiFi issues
Hi we've been having issues with our internet for for the last few days now it keeps dropping in and out I thought it might have  been an issue on the line but all seems ok according to diagnostics
Re: WiFi issues
@Tara66
The first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
