Discussion topic: WiFi issues
Message posted on 30 Oct 2025 08:30 PM
WiFi issues
My WiFi isn't working. There is an orange light on the hub under voice. Why is this?
Message posted on 30 Oct 2025 08:36 PM
Re: WiFi issues
@Rhian1996
If you haven’t done it yet you can use this link to check to see if there are any broadband issues or outages nearby.
Note: It doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps retry later.
