Discussion topic: WiFi issues
Message posted on 22 Oct 2025 11:16 AM
WiFi issues
Hi very often and yet again today my WiFi is not working , service checker is showing as all good but my devices and not getting WiFi
Message posted on 22 Oct 2025 11:23 AM
Re: WiFi issues
@Ewelinaewelina
You can use this link to check to see if there are any broadband issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour or so later).
wfh: Remember Sky broadband being discussed here is a domestic service and whilst it's fine for those customers working from home to use it, they won’t receive additional or quicker support.
