Discussion topic: WiFi issues
This message was authored by: SReave166
WiFi issues
Hi, my WiFi keeps going down. I have had issues when I have 4 green lights on my router but keep getting 3 green and one orange and nothing works at times. Please help.
Re: WiFi issues
@SReave166
Use this link to check to see if there are any broadband issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour or so later).
