Discussion topic: WiFi issues
This message was authored by: Shaz821
WiFi issues
We had fibre installed into the property but no connection from the fibre box to router. The cat 6 cable has been attached by us between the fibre box and the router but the WiFi is lagging. Dropping in and out. Saying no IP address. I need internet! It was working until you installed the Fibre.
Re: WiFi issues
@Shaz821 When did you have it installed, and what are you seeing at the hub side?
