Discussion topic: WiFi issues
This message was authored by: Frankie051
Message posted on 02 Sep 2025 08:58 AM
WiFi issues
WiFi keeps going on and off for the past few days, I keep trying to turn it off and back on to restart it b ur it only works occasionally and it's off at the moment and I can't get it to work
Find out more
Message posted on 02 Sep 2025 09:23 AM
Re: WiFi issues
@Frankie051 using a mobile connection run the service checker in the My Sky app if it doesnt tell you Sky arexaware of the fault then call them to report it so it can be checked out.
