Discussion topic: WiFi issues
Message posted on 20 Mar 2025 10:47 PM
WiFi issues
My WiFi connection has been down and really bad also one of my sky glass isn't working and I'm still paying for it
Message posted on 21 Mar 2025 05:36 AM
Re: WiFi issues
@Sh34
In the UK two WORKING days is the service level agreement between ISP’s and Openreach for fixing a fault.
The below link explains the Ofcom agreed auto compensation scheme which Sky operates for when there is a TOTAL loss of Sky Broadband or Sky Talk for UK customers.
https://www.sky.com/help/articles/auto-compensation
If you have a total loss of service and it isn’t fixed after two full WORKING days from when Sky are notified of the fault, you will become eligible for it. It’s applied 30 days after the fault has been repaired and will come in the form of a credit appearing on your Sky account (from 01/04/24 the rates are £9.76 per day). There is no equivalent scheme in place for customers in the Republic of Ireland.
As Sky broadband discussed here is a domestic set up there is no extra or quicker support for those working from home.
