Discussion topic: WiFi issues
Message posted on 16 Jan 2025 08:10 PM
WiFi issues
I tested my WiFi speed on the MySky app and it's showing speeds of around 500mb/s. My WiFi doesn't reach about half the rooms in my house (standard size home) when I tested my WiFi on a PC it's showing speeds down at 2/3 mb/s which is worse than my last house which didn't even have fibre optic broadband
Message posted on 17 Jan 2025 07:39 AM
Re: WiFi issues
@AB102 wifi dignals strngth is determined bybthe layout and type of construction of you home. This means a small 2 bed cottage with stone walls can be more difficult to network than a modern large home. Many homes require more than a single wifi source my own included. You can help yourself to some extent by making sure the hub is out in the open on a surface above obvious obstructions like radiators. You msy need a longer etgernet cable from the ONT unit to the hub to achieve that.
Aftervthat it is down to looking at getting more kit you could pay Sky for their https://www.sky.com/help/articles/sky-wifi-max bundle or as I did myself buy a whole home wifi set up which need not be expensive.
