Discussion topic: WiFi issues
This message was authored by: JulieEast
WiFi issues
Anyone else having wifi issues right now?
It has disconnected and the app states "something wrong with your wifi" but once it does the checks its showing "everything is gone"
Re: WiFi issues
@JulieEast itvis highly likely with 6 million broadband customers a fewcthousand will have lost connection at any time. Loss of connection in thecesrlybhours is often down to the need for essential maintenance if thst is the cause for you then your service should be back by now. Openreach often dont tell Sky unless it affects a large area. Work is done overnight to cause disruption to the least people.
