Discussion topic: WiFi issues in other rooms
This message was authored by: 5am0
Message posted on 14 Dec 2025 12:04 PM
Recently just switched to Sky gigafast and I'm experiencing problems connecting in other rooms. The signal is poor along with the speed. I have tried moving the router to try improve this but this hasn't helped.
Find out more
Message posted on 14 Dec 2025 12:10 PM
Re: WiFi issues in other rooms
Try going through this to see if it helps:
If not and if you have Wi-Fi Max on your account then Sky will supply up to 3 pods as you can read about here:
Select "No, I still need help" at the bottom on the above link.
