Discussion topic: WiFi issue
This message was authored by: Russell37
Message posted on 09 Dec 2025 02:12 AM
WiFi issue
Problem with WiFi, on-off-on-off, 100 times per day
Find out more
Message posted on 09 Dec 2025 07:07 AM
Re: WiFi issue
@Russell37 you need to determine whether you have an issue with the WiFi connection in your home or the Broadband connection to the hub. The essiest way to do that is to look at the lights on the hub when you lose connectivity and follow the steps here https://www.sky.com/help/articles/hub-lights-explained-start
