Discussion topic: WiFi issue
This message was authored by: Abukobir
WiFi issue
WiFi issue, no connection.
Re: WiFi issue
@Abukobir
If you haven’t done it yet you can use this link to check to see if there are any broadband issues or outages nearby.
Note: It doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps retry later.
▪️I AM NOT A SKY EMPLOYEE ▪️
