2
This discussion topic has been answered Discussion topic: WiFi issue
This message was authored by: LeeWJS
WiFi issue
Voice light out have sent photo of setup - no wifi
Re: WiFi issue
@LeeWJS
If your Sky broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
Not sure what you mean by "sent photo of setup"
Re: WiFi issue
@LeeWJS
Avatar for LeeWJS
Re: WiFi issue
Cheers sorted - sent photo was through app support thought I was on live chat 🤦🏻‍♂️
