Discussion topic: WiFi issue during team
This message was authored by: Tboe
The Wi-Fi keeps dropping out when I am on work meetings with colleagues this is proving very awkward. Please call back with a solution
Re: WiFi issue during team
@Tboe
No one will / can phone you. Your Community tag name isn't linked to any Sky accounts you have so no one knows who you are. l’m afraid you aren’t speaking to Sky Customer Services by posting here. This is a customer ➡️ customer discussion forum where we try to help other Sky customers.
If you have broadband problems use this link to check to see if there are any issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour later).
