Discussion topic: WiFi isnt working
Message posted on 18 Nov 2025 12:24 AM
WiFi isnt working
Ive tried unplugging an resetting the box but still no WiFi
Message posted on 18 Nov 2025 06:45 AM
Re: WiFi isnt working
@JennaMcintyre
When there are issues between midnight and 7am it's quite possibly going to be essential overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep. Hopefully it'll be back up and running before 7am.
If not use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps try it again later).
