Discussion topic: WiFi isnt working even after checks?
Message posted on 01 Jun 2026 05:21 PM
Message posted on 01 Jun 2026 05:24 PM
Re: WiFi isnt working even after checks?
I can't see there being a promise of no issues. No ISP can guarantee that.
Even if you’ve already tried it use this link to check if there are any broadband outages or issues locally that may identify a known fault, perhaps affecting multiple households ~
Working from home?; Sky broadband discussed on here is a domestic service and whilst it's fine for customers working from home to use it, they won’t receive additional or quicker support.
Message posted on 01 Jun 2026 05:26 PM
If everything appears to be working as normal so the line test shows no faults and the lights are all lit on the hub then you might have a poor signal throughout your home as this is something that comes up on here on a regular basis so try going through this to see if it helps:
If not and if you have Wi-Fi Max on your account then Sky will loan up to 3 pods as you can read about here:
So you can either call them on 150 from a landline phone or a mobile that has a Sky sim in it or Select "No, I still need help" at the bottom on the above link.
