Discussion topic: WiFi isn’t working
This message was authored by: Rachel284
WiFi isn’t working
My broadband router isn't working and is flashing amber
Re: WiFi isn’t working
@Rachel284
If you are new to the forum, or this is your first post, then welcome to the Community which is predominantly made up of Sky customers helping other Sky customers. You aren’t talking to Sky by posting here.
Broadband and Wi-Fi are different. Broadband is the internet connection provided by your ISP (Sky), Wi-Fi is the wireless connection between your hub and devices.
Use this link to check if there are any broadband issues locally that may identify a known fault which could be affecting multiple households ~
(this won’t necessarily identify a fault that only affects your address).
If you’re still having problems you may need to report it to Sky. The easiest way is to dial 150 free from your Sky Talk landline (if it’s still working).
🔸Various hub lights; This link provides information about the coloured lights you may see on the various hubs
🔸Red light on ONT?; See this link ~
🔸Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky allow customers working from home to use it, they won’t receive additional or quicker support.
