Discussion topic: WiFi isn’t working
Message posted on 31 Jul 2025 03:15 PM
WiFi isn’t working
My WiFi isn't working
Message posted on 31 Jul 2025 03:24 PM
Re: WiFi isn’t working
@wifidoesntwork1
If your Sky broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
If you’re still having problems you may need to call Sky to report it. The easiest way is to dial 150 free from your Sky Talk landline if it’s still working.
