Discussion topic: WiFi isn’t working
This message was authored by: Becky124
WiFi isn’t working
My WiFi isn't working only the power light is on. I have rest it but nothing had happened.
Re: WiFi isn’t working
@Becky124
Wi-Fi is the connection between devices and your hub. Broadband is the actual internet connection provided by the ISP (in this case Sky).
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
