Discussion topic: WiFi isn’t showing up
This message was authored by: xmaudex
Message posted on 07 Oct 2026 09:55 AM
I had a new router fitted yesterday but it's not showing up on the search and it keeps saying I'm connected to the old one I've tried everything and it's still not showing up to join the new one
Find out more
Message posted on 07 Oct 2026 11:19 AM
Re: WiFi isn’t showing up
@xmaudex if it is replacement white Sky hub sent by Sky it will be programmed to use the same SSID andpassword as the one it replaces. Sky do tghis to simplify the swap over.
