Discussion topic: WiFi is rubbish
This message was authored by: Chelsealee1
WiFi is rubbish
My WiFi constantly keeps dropping and not working which then affects everything else it happens at least 6 times a day if not more sometimes
Re: WiFi is rubbish
@Chelsealee1
If you haven’t done it yet you can use this link to check to see if there are any broadband issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again later).
