Discussion topic: WiFi is not working
This message was authored by: JulieBrown
WiFi is not working
I have had an issue all day in that the WiFi is not eorkingi cannot connect any devices, I have no tv cannot make phone calls, anything that requires WiFi. I have reset, switched on and off multiple times but nothing. The lights on the router are all green but not connecting.
Re: WiFi is not working
@JulieBrown
If you have broadband problems use this link to check to see if there are any issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour later).
Avatar for JulieBrown
Think I'll have to contact sky as broadband is fine it's saying there is no issues but I just can't get devices to connect.
