Discussion topic: WiFi is down
This message was authored by: Fran210
WiFi is down
Hello
my WiFi has randomly stopped working and if tried everything that it says to do, such as restarting it.
Re: WiFi is down
@Fran210
Wi-Fi is basically the connection between devices and your hub. Broadband is the actual internet connection provided by the ISP (in this case Sky).
If your broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
If you’re still having problems you may need to call Sky to report it. The easiest way is to dial 150 free from your Sky Talk landline if it’s still working.
For customers working from home please remember that Sky Broadband is a domestic service so you won’t receive any quicker or extra support.
This message was authored by: IHATESKYWIFI
Re: WiFi is down
SAME IT STARTED ON THE SAME TIME AS U
Re: WiFi is down
@IHATESKYWIFI
The same advice applies.
