Discussion topic: WiFi is a joke -
Message posted on 21 Jul 2026 08:39 PM
WiFi is a joke -
WiFi & internet connection keeps failing- sky Q mini boxes & boosters lost connectivity and won't connect.
constant rebooting of systems to get to reconnect then fails again.
loss of WIFI means loss of data - burning through data due to loss of WiFi connections.
was sold as being as good as BT set up we had - utter **bleep**
Message posted on 21 Jul 2026 08:54 PM
Re: WiFi is a joke -
Message posted on 22 Jul 2026 05:39 AM
@CosmoW if you switched from a BT hub to a white Sky hub the Q minis should still be networked from the main Sky Q box as they were before so it is strange if they have started misbehaving. How many Q minis and Q boosters do you have? I would getva WiFi analyzer app and check thst the issue isnt simply interference.
The Sky SR213 hub appears to have less range than the equivalent BT/EE unit. sky arexaware of this do seem to discount their WiFi Max add-on which can give you up t o 3 WiFi extenders matched to the hub.
Message posted on 22 Jul 2026 08:57 AM
Thanks for the help - the minis have been ok and connect back to the Q box, but regularly fail to make the connection and find the internet.
we already have Q boosters for them but the boosters are now failing to connect.
all in all its looks like the hub is just fading away
